After installing my Battleborn batteries with the IQ4-LIFEPO, and reprograming my Bogart Engineering battery monitor and solar charge controller, everything has been working well.
I have one remaining power issue and finally isolated what was happening. Because I have an AGM truck battery, I did not replace the SurePower battery isolator because I did not want my LiFePO4 configured solar system charging my AGM truck battery until I better understood how it all worked in practice. I noticed that although the camper batteries had reached 99-100% at end of day, They would be down to 90-95% in the morning without anything on on the camper. I had pushed in the big chrome switch. So where was the power going?
While watching the battery monitor amps reading, I noticed about 0.8 to 0.9 amps draw on the camper batteries. The only place it could be going was forward to the truck. The SurePower battery isolataor has a solenoid that consumes about 0.9 amps to keep the relay energized. I pushed my keyfob unlock button and watched the truck interior lights come on and the amps went up to about 2.5 amps. Pushing the keyfob Lock button, I saw the amps drop back down to about 0.9 amps as the interior lights went off. Checking the truck voltage showed 13.2 volts. This is after the truck had rested for more than 12 hours and 12.5 to 12.8 volts would be more appropriate. In other words, the internal truck DC power sysem is my parasitic load. My expensive LiFePO4 batteries are float charging my truck battery and powering the always on truck systems and keeping the isolator relay energized.
Rethinking my previous decisions, I may disconnect the truck and camper electrical systems entirely.
