Going to pick up a used truck camper in 9 days driving from Florida to Tennessee and the tork lift t2308 ft tie downs are out of stock cant find anywhere. I have 2006 toyota tacoma is there something else I can use to tiedown to?
Haven't seen this till now, did you figure it out? I would drive pretty slow if mounting to nerf bars...real rock sliders would be ok though.
Are you able to tie it down inside the bed?
I use the rear tie down points in the Tacoma bed and when I bought my camper I put eyebolts in the front drain holes in the bed. I have since moved to rock climbing bolt hangars under the Bed-to-frame bolts which are cheap and easy:
