foakes
View attachment 42340Hi Everyone —
Getting our 2002 Six-Pac T100S camper ready for camping.
It mounts on our 2002 Toyota Tacoma 4X4, 3.4 V6, Manual Transmission truck.
Got everything working — except an issue just came up with the electrical when plugged into shore power.
The GFCI outlet to the right of the sink tripped — and would not reset.
Bought a new GFCI with an indicator light — it also will not reset — red indicator light is present.
Circuit breakers are tested and good.
All fuses in the Newmark 30 Amp converter are good.
Battery is at 12.9 Volts.
The lights and hood fan work on the drivers side.
The refrigerator, furnace, will not work on the passenger side.
The water pump works.
When the converter is momentarily powered — it makes a “clunk” sound — but doesn’t seem to do anything else.
I am suspecting the converter since all plugs and wires seem to have continuity according to a volt tester set on Ohms.
How do I go further to verify it is the converter — or something else?
Everything was working fine until yesterday.
Appreciate in advance any help.
Plus, if it is the converter — do I replace with the same Newmark 30 AMP — or do I go to something else?
All the Best,
Fred
All the Best,
Fred
