So I picked up my new GMC 2500 on 1/17/15 and got my new FWC Hawk installed on 1/22. Naturally I had to take it around the block for a test drive. Of course living in N. Cal my block is pretty big.
I drove up i-5 past Shasta and then over to Tule Lake and Lava Beds NM. Spent Friday night there and then drove back via Canby, Falls River Mills, Buney Falls, Highway 44, Moony Road to Westwood, Westwood to Highway 99 and back home. (About 600 miles + or minus)
The truck/camper seem well balanced, but I will probably do a minor upgrade to rear to handle sway. Power with the duramax is obviously no problem. Fuel milage was 17.5 MPG - very happy.
The FWC heater kept me plenty warm with overnight temps into the high 20s - condensation was not much of an issue, but it was really dry up there.
Fridge (12V/110) seemed to work fine, but was an issue with the temp control switch. It seems to be installed backwards or I am not reading it right - basically there is no way to tell what temp it is set at. Either way not an FWC issue. I prefer the Dometic temp control on the icebox type units that I already had - much more precise than a 1-7 scale.
Did not have a chance to test water heater beyond turning it on.
Exterior lighting works great - esp like the exterior down lights.
Not happy with battery life - but that is my own doing since I only ordered a single group 24 battery from FWC. I have an upgrade in process which should be running by next week.
All in all I am very happy.
Only downside was it the lack of ice at Tule Lake - not good weather for Bald Eagle pictures. Temps got into the low 60s during the day - very unseasonable.
