The Unshaven
Howdy All,
I am planning out building a fridge slide for my 37 quart ARB. I am going to install it where the ice box currently resides in the FWC Fleet, front dinette. I am in the group "ice box sucks" and want to put the space to a different use. This topic is not about the merits of where an ARB should go or what better to do with the space once the ice box is removed. I want to put my ARB there because I feel like it. You may opine on those subjects if you please, just know that I never let good sense get in the way of my feelings.
What I am hoping for opinions on is whether or not to leave the Styrofoam insulation in place that was installed behind the ice box. The cons of doing so that crossed my mind are as follows.
- Ugly to look at (feelings again...). Would require me to hide it with more wood work, adding to cost and weight.
- Although it will be open in front, will constrict the space, leading to less air flow and warmer temps. around fridge, leading to more power draw?
- Would hold in the warmer temps. from the fridge running, opposite from the original point of the Styrofoam keeping outside heat away from the ice box.
