badtoytrd
I may be setting myself up to get hammered here but I am in the beginning stages of conducting my spring maintenance. I have fought some minor leaks since buying a used Fleet. I believe one of the major issues was the aluminum roof rack FWC installed. I removed that last spring and filled the holes with JB Weld and 5200 which solved most of the problem. I also believe that the rubber weather strip along the front and sides has been smashed over the years so I am going to insert some backer rod to give it some shape again. All of that being said I am wondering if anyone has used Plasti Dip to paint there roof. In theory, it should work well at sealing everything as it is a "rubber" paint. I would love to hear your thoughts.
