So what do you use to quite the squeak caused by the read door hinges?? Ya dw40 works ,however it collects dirt when off roading.so is there a dry lube that works???
Rear door i assume. I tried teflon dry lube but just couldn’t get it to work into the hinge. I ended up using TriFlow oil with teflon (a wet chain oil), worked the door as I oiled each part of the hinge, then wiped it away. It mostly quieted it at that time, but by the next day the oil had flowed in and the door has been completely silent for a few weeks now.
