Squatch
My Eagle shell does not have the Yakima tracks. Being a cyclist I'm already heavily invested in rack stuff. Most of it the older rain gutter style. I also have 8 of the Yakima roof mount artificial rain gutters. I've talked with a couple of folks who have used these on their camper with no issues.
I've ID'ed 6 places along the 2 heavy beams in the roof where they intersect with like sized cross beams. About a foot from each end and in the center. This will allow me to mount 6 feet for 3 crossbars in the strongest spots on the roof. The roof rack will hold the 160 watt solar panel down the passenger side front 2 bars. and the solar shower down the outside of the drivers side forward. This should prevent the vents from shading the panel. It should also allow room to occasionally carry my solo canoe. It also keeps the shower tent forward away from the furnace vent in the rear.
This is the mount style I'll use. The cross bars I have for Yakima are too short so I'll probably get 3 aluminum longer bars to save some weight. I've used these style mounts on quite a few truck caps with no issues over the years. I don't intend to get stupid with weight up there for sure. They will be bolted through the roof and sealed with a Sikaflex type sealant.
I need to order some marine grade cabling, connectors, and other small parts for the wiring. Then make decisions on just where to mount the electrical stuff. I also intend to mount an outboard electrical connector on the drivers side rear under the edge of the camper. This will give me a place to plug in the portable panels either in addition to the main panel or instead of. The roof stuff will be easily removable with these mount should the need arise. But also lockable.
