If I can ask a stupid question, I am going to add a second battery in parallel, how do I add a shunt for each battery, and how will it know which battery it is seeing if both are connected?
Well what I know wouldn’t fill a shot glass but if you are making one big battery outta two.... why would you need two shunts? They are performing as one battery unit.
All I would do is disconnect occasionally and put an ohm volt meter on each post to test each battery separately. Would only take a second or two. Otherwise if they are the same type battery attached in parallel they should wear the same. Not a good idea to attach two batteries that are different ages.
This is a great question. The BMV has an option for "mid point" voltage testing, but that only works for series connections.
As Buckland suggests, the two batteries should be identical in makup/brand/age. To use the shunt as intended, I would suggest using a buss connection for both batteries to ground to, and from there go to the shunt. You will NOT be able to see individual SOC for each though
I’ve wondered when someone would ask this question.
For a short time, it bothered me that this info was unavailable, but the cost of obtaining it is well past the point of diminishing returns, IMHO.
If it is a concern, attach the positive lead from solar & load on one battery, and place the negative lead from the shunt on the other battery, swallow hard & enjoy your camping. Life keeps getting shorter.
