Specifications other questions
Idahostat
May 29, 2017
45
Boise, Idaho
Hello
Can some one point me to a list, reference for the dimensions of the models ( I get that the length varies ), trying to determine width, base to shoulder ( trying to determine size for fitting to a utility body, found a set of images from expedition forum from someone who has done this, the man had the skills and tools to modify his recycled utility body and he already had a Alaskan to work from ). Depth of standard box on truck varies depending on year/decade of manufacture. Utility bodies varies by Mfg for different markets and DRW or SRW.
Alaskan does not have dimensions other than length and wet/dry weights that I could find on their site.
If you have yours on a ___X____ truck is the clearance the same over the cab have you observed? Assuming you see and talk with other Alaskan owners.
Are you using a wind deflector/foil?
Terence
Here's what I have: not all campers have the bump outs behind the wheel well, so it really depends on what year and style your Alaskan is.
Hello "thisOldCamper"
Thank you for the response.
48" width, plus the difference for 8" for each side ( approximately ) for the storage with a depth of 21" deep by 19.5" in height.
2017 Ford bed rail depth is "currently given as 21.1". Ford SuperDuty PDF source.
So a riser/offset/storage preplanning, unless custom camper made for "2017 Ford" bedrail depth.
So scouting of used service bodies and "Alaskan" campers with tape measure in hand!
Terence
be careful.....utility bodies typically have a 49" bed width....many of the older campers have pop outs of different widths at the rear section at the refer and comode/closet area....I've seen anywhere from 6-10 inches in the pop-outs...Alaskan made a special version just for utility bodies...straight away full width all the way back
with an older NCO you will be raising the bed...but the utility configuration will be the key to the height...so an old utility body on a new frame with an older Alaskan will require some interesting measurements
M2C....get your truck, find the camper you want...bring it home with the bed on the truck...then find the bed you want, get it mounted...and make the adjustments...mount the adjusted camper....(you'll be able to camp in the camper in the time your bed hunting.... :D
if you go CO you will have additional "measurements" to deal with...standard raise on a newer ford pickup is a 4" on older campers in CO configuration to clear the cab by 1"
Some of the older propaganda from Alaskan did include a service body reference. And as I mentioned in my original post over on the "overland forum", someone detailed their conversion from a standard bed to a utility/service body bed and the necessary widening to handle the rear expansion to support the space for the bottle gas and the cassette toilet on either side of the door of their Alaskan.
More tools and technique than I posses.
Terence
