Squatch
Today this pickup saw the light of day for the 1st time in well over a year. I pulled it out of the garage with the vintage Cub Cadet.
My bud Mario was here as was my BIL. It was an interesting day. As usual there were bugs to be worked out. 1st was a no start which had several reasons. So I did a jumper test at the fuel pump relay and decided the fuel was way old so we used the fuel pump to pump it into a storage tank. There wasn't much left in it and the newest was 3+ years old. So we drained the tank(fuel was rusty colored). In the process I discovered the rubber fuel line at the tank to fuel filter was leaking. Didn't take long to realize this was the original line and fuel filter from '88! :shock: The line was falling apart. So then a run to the parts store for a fuel filter and a couple of cans of fresh gas. While there an old coworker on his way home from work saw Red Beans out front and stopped. We had a nice quick visit.
Let me tell you the fuel line at the tank was never intended to be changed with the tank in the truck. It was a bear and required one hand each from 2 people from opposite sides to get it clamped. So new line, new filter, we tried to start it again and didn't take much to realize I had the distributor off by one tooth as usual. I do this every time. Did I mention that's not real easy to get to either. At this point it would do you folks well to visualize The 3 Stooges. Once we got that straightened out she started fine almost! Massive vacuum leak. Huge hiss and engine didn't want to idle at all. We checked a couple of normal things. Then my BIL said, What's that hole for? Is something supposed to be there?" It seems that after sand blasting the upper plenum I had removed a big(19 mm wrench) plug from the plenum to clean it. Bear in mind I had never touched this plug on any 2.6 in all these years. So it never occurred to me to replace it. So I checked a spare plenum and there it was. I pulled it and put it in and problem solved.
Set the timing close enough and pulled the throttle cable tight and let her run for about 35 minutes between 1,500 + 2,200 rpm to break in the cam. She ran real good and very smooth. The machine shop and original builder must have spent some time on balancing. The engine ran very still in the mounts. It also had amazing oil pressure and ran very cool. Happy to report the fan clutch was noticeable when it kicked in. Which was not often. And no white smoke from the exhaust. Hot Damn!
So after the break in I slowed it back down and lubed the linkages at the throttle body. Then did a quick drive down our private road and back. Truck felt nice. So a bit more fine tuning to timing and readjust the valves again and change the oil. And the engine should be settled. Tomorrow I go to the MVA and get her legal.
Then soon the bed comes off and the rest of the frame gets painted and I'll probably bend new hard lines front to rear for fuel, return, vent, and brakes. Then comes the new springs.
It's been a long time getting to this point. I hope things continue to roll well!
