brianjwilson
I haven't seen those spring liners before. The Tacoma OME springs are notoriously squeaky as the upper leafs do not have the pads between them. Their long upper add a leaf also doesn't have one. I ended up pulling mine apart after a couple months, cleaned them and used strips of adhesive backed epdm pond liner stuff on the out 6" or so of the springs. Works great, until they start working themselves out of the spring pack. Grr. I've seen other people run massive zip ties over each leaf toward the end as well which seems to work ok. Frustrating that OME doesn't at least punch holes in the leafs so you could put pads on them.
So I just searched Google and found these, like you're using....
http://www.yogisinc.com/index.cfm/page/ptype=product/product_id=866/prd866.htm
I wonder how they hold up... I'd be afraid of them cracking and bracket up, then leaving loose u bolts.
