Squatch
More progress. For the most part the rear end of the truck is done except for the bed and a few small things.
Brand new OEM calipers that I painted. New Powerstop drilled rotors and pads that have been on the truck for a while but driven about 100 miles.
Timbren overload springs to replace the factory bumpstops.
Independant4x SS aircraft grade flex lines. Hand bent Cunifer brake lines with SS nuts and gravel guard. New skyjacker nitro shocks.
Black hose is extended axle vent.
Next up is to clean and reline the fuel tank. That and bend the hard lines along the frame for fuel, return, tank vent, brakes. I ordered 3 rolls of Cunifer tubing today. It should be here next week. This stuff is 90% copper, 8% nickel, 2& ferrous metals. It's super easy to bend and brake lines seal well. It also doesn't rust!!!!! I had almost enough SS line to make the hard lines. But it is so hard to work with that I went for the easier to use stuff. especially since I'll be doing this under the truck on not on an exposed frame in the drive like I did Red Beans.
http://www.cunifer.com/
