Squatch
Mini update. The camper has a removable front window facing the truck cab. it also came with a boot to seal out the weather.
A while back I had obtained a NOS opening back window and gasket for the truck. I wanted to get this installed before I installed the gas tank, driveshaft ect. Plenty of room to stand on the ground behind the truck cab now. Once those things are installed that won't be so easy. I needed me on the inside and someone on the outside to do the job. I have only done this kinda stuff a couple of times and the last time was several years ago. A couple of weeks back a friend came up to help me with this. The old window came out fine without breaking. We had fits with the new one though and ended up tearing the weatherstrip. So we had to abandon the job. I got another new weather strip and today we tried again. We learned a couple of things the 1st time and that helped. We also lubed everything a lot more with silicone spray. It was a mess but we succeeded. The window is in.
After some clean up.
Now I have a pass thru to the camper.
Now that this holdup is done I can get the gas tank back in and hook it up. Then comes a quick rebuild of the driveshaft. I have new U joints and a new carrier bearing for the 2 piece shaft on the bench waiting.
