The problem with the F-150
John D
Jan 4, 2007
465
Southeast
Having reported fuel starvation problems with the F-150 over our trip of 40 days to the Pacific Northwest, I thought some readers would want to know how the diagnosis of the problem is coming along after we got home. Today, I removed the fuel tank in order to examine the inside of the tank and the fuel pump. We had seen a great deal of rust being trapped in the 10 fuel filter replacements while on the road. Replacing the main in-line fuel filter had not resolved the problem, but it had helped. It also suggests where to look further when we could take off the fuel tank and obtain the needed repair parts if the problem was as expected.
Upon examination, the tank and the inlet filter to the fuel pump appear to be clogged with rust. The clogged inlet filter was most likely being collapsed over the inlet and restricting the fuel flow. The attached image shows the inlet filter cut apart with and trapped rust.
Toward the middle of the trip, it became apparent that shutting off the engine and restarting would dramatically reduce fuel starvation. Unfortunately, this fix only lasted for about 100 miles. We repeated this over and over, even shutting down the engine while coasting down hills.
We began to think about a collapsed inlet fuel filter. This filter is supposed to catch gross contamination and water. Fine contamination is meant to be caught by the in-line filter. If there is a gross amount of rust or other trash in the tank, it may actually clog this small inlet filter. So, we limped back to Alabama while crossing our fingers that the fuel pump would not fail, shutting down the engine and restarting when it starved. We added 2 cycle oil in the fuel to provide extra lubrication for the pump. I think we were lucky to get home without a major breakdown.
The solution chosen here is to replace the fuel tank with a new one and the fuel pump with a new assembly. The cost of the parts at AutoZone is 400 bucks. A repair like this at a Ford dealer would cost well in excess of a grand and it would have delayed us for about a week as the new fuel tank was shipped in. That makes this $4,500 truck not look so good. Nevertheless, this is what happens with trucks. No use worrying about it, just cough up the money and mark it down to another camping experience.
As second posting below shows the old fuel pump assemble and the new one. Perhaps this is instructive to some and I will report later if this actually fixes the problem. _John D
Here is an image of the old pump assembly below and the new one in the top of the picture. This new pump assembly is suppose to be an improved unit that will tolerate alcohol better.
maybe i could use a new pump....so i could tolerate alcohol better!
keep going! lets see what happens!
Brand new 30.5 gallon tank, pump, intake filter, and in line filter are now installed, four hundred fifteen bucks worth of parts and a day of priceless (meaning not valued) labor.
