I've seen discussion on the pros/cons of load range D vs E tires, but my 1/2 ton F150 supercrew 4x4 has load range C tires and there does not seem to be a D range tire in that size with all terrain tread, 275-65/18. I know the E tire is overkill for a 1/2 ton truck but is seems that the C tire does not leave a lot of margin with 2600 lb rating at 44 psi. I am using a fully loaded Hawk on the 5-1/2 foot bed so it hangs out the back a foot or so; and so there is more weight on the rear axle. One person suggested maybe E tires on rear axle and C tires on front axle. Also, I'd need to confirm that the alloy wheels can take up to 80psi with the E tires as I've heard of wheel failures (mostly steel wheels though). I'd be interested in hearing about the ride quality with E tires on 1/2 ton trucks, especially with the camper off, since I frequently take the camper off.
Dave
'06 Hawk - '05 F150 Supercrew Lariat 4x4
Mill Valley, CA
PS- upcoming trips includes Death Valley April 7-9, Eastern Sierra April 29-May 3
Dave
Mill Valley, CA
