SageRoamer
- Joined
- Nov 17, 2020
- Messages
- 5
Has anyone used the frame mount torklift system with the torklift XL spring turn buckles on their fwc hawk?
SageRoamer - Yeah, other than the $pend and the bulk on the outer perimeter with the Tork Lift setup, I think there is a lot of upside, . .If you put yourself in a door jam and brace with your feet, seems like sway force east to west up top is greater than if you brace at a higher point (i.e. elbow level) . . . This is not to say that huge bumps at speed wont compromise either setup, but there is some logic to it as you won't see a Bigfoot or any other heavy cabover secured to the bed/floor. Its also cool that you are ready to go with any other cabover should you choose to defect!SageRoamer said:Thanks for writing about your experiences with this setup I believe I am going to take this route I have a new truck with an older hawk and I didn't want to drill into the bed for mounting the camper
