Hello,
I just became the proud owner of a 2006 Hawk. The problem is, I don't have a truck yet. It seems like my truck options (like much in life) present tradeoffs between things including power and size etc. The truck will probably have the camper on full time. I like to be on 4WD roads a lot, going to remote places (like Baja and Canyonlands) though I am not a rock crawler type. I am also hoping to take a kayak or two on some trips, which I figure would increase weight about 100 lbs. I am ok with upgrading the suspension if that is what is needed. On one hand, I would probably like an old style Tundra ('06), or other half ton truck, but am concerned that it might be a bit underpowered and/or not a beefy enough suspension for that amount of weight (even with airbags and maybe a sway bar). The newer Tundras, 3/4 ton and 1 ton trucks seem really large, especially for going on 4WD roads, but they have more power and better stock suspension. My preference would probably be the smaller 1/2 ton truck, but only if it is sufficient in terms of power and load management, etc. Any thoughts and/or recommendations from this learned group re truck types and/or suspension upgrades to go with it? Thank you.
