Otis
My Sureflo water pump won't move water(4xx9 series in a 2013 Eagle without a water heater). It just buzzes a bit but no water is pumped. The water tank is filled to over flowing.
What I've done so far:
Let the pump run for 2-3 minutes
Checked the screen on the pump - it is clean
Unhooked the inlet side of the pump, turned it on and felt suction, so it seems the pump is working
Is there a way to prime the pump? Fill the inlet side tube with water?
Thanks good folks for any tips and insights -
Best regards
Best regards
