PackRat said:
Ouch!
I think you either have the 8' NCO and take a loss and let someone who wants a Project have it or fix it. Problem is you found it is just too SMALL in there for your needs. You need a bigger Alaskan but any camper big enough is possibly too much for your truck. If it does have a 3000 and 6000 capacity on the axels any of them should work unless your weight is ALL on the rear perhaps. I don't recall seeing if you have an 8' bed on the truck, but with those weight allowances and if...if....you have a 3/4 ton truck then it should be OK. I think you need to describe your truck in DETAIL as guessing and not getting a response isn't helping. A pic of the truck and a pic of the VIN tag showing weights helps tremendously.
Once others who have the same truck as you do see what you have they can suggest which way to go.
As it stands....your 8' Alaskan needs too much work apparently and cost you too much but what are you going to do? What is the goal here....find one to use this summer or work on one that you paid too much for that needs too much work and isn't big enough anyway?
One heck of a dilemma though.
I didn’t specify the truck the camper would be on, because up to this point I didn’t it was relevant to the discussion. The camper will be going on an IH 1310 4x4 dually, more than enough truck for any Alaskan model I’m aware of. The bed is whatever we want to weld up because it was formerly a wildland fire truck, and as such has a big steel flatbed.
The Dodge I mentioned is the only means I could conceivably utilize to fetch any camper that isn’t nearby because: 1. The IH is in Wheatland WY, right now needing a rear main seal, bed fabrication, and several interior components. 2. When it does become roadworthy, mounting the camper won’t be a simple slide-in procedure because of the mounting system envisioned, width of side boxes, etc. Mounting it in someone’s yard or curbside won’t be feasible, so the camper has to be brought to the IH, and my Dodge isn’t the right truck for that.
I bought the 8’ NCO more on a sentimental whim than good sense, and I realize that now. A CO just makes more sense from a space standpoint, and I have the capability to haul one, so I might as well. I’ll take a beating on the 8’ I already have, but so be it; no sense following one bad decision with another. I’m not going to let a dilemma form from one (pretty damn) stupid decision. Deadlines shouldn’t be too much of a factor, either, since I’ve set the deadline for completion at Memorial Day Weekend of next year.
I have a lot of patience for working on old trucks (and campers, it turns out), but NONE for computers and their arbitrary foibles, so you’re unlikely to see any pictures of anything from me until I can post them from Tapatalk. I save my energies for challenges that are enjoyable.
