Hi All,
My camper's group 24 Interstate Deep Cycle just died from over discharge (I forgot to turn off the kill switch
). I've been thinking on what to get next, it seems both LifeLine and Trojan are good candidates but both are pretty $$$. Any suggestion on what to get?
Alex
Hi,
These guys have a nice site. If you dig around there is a lot of information. They like the AGM batteries, including the Deka.
http://store.solar-electric.com/batteries.html
It is easy to kill a battery. When I am not really using the camper, I have put a cheap Walmart deep cycle ($60) in the unit. For the most part there is not much difference. The cheap batteries can go bad, but Walmart does replace for a year, something like that. One theory is buy cheap and just replace the thing fairly often. I'd go premium on a two battery system. They interact and the expensive batteries probably age more predictably.
In theory the AGM is lower resistance, so it will take more charge, charge faster. My Tacoma as wired to the camper system only charges about 12 amps an hour. That makes it hard to recover from a deep discharge just driving.
A lot depends on how hard you will use the battery, how many cycles per year, how deep. AGM is safer and does not really require venting. Cheap batteries are lighter, which suggests a lot less lead in the plates. If I were using 30 amps a day, I would go premium. I actually use about 15 amps a day and carry a decent solar panel. My original Interstate has lasted 40 months, seems OK. Cost per year, cost per night, is OK.
George
