Who's Installed an inverter?
I also have a 300W inverter, only ever used a couple of times to charge my MacBook. If I were to do it over, I would ditch the inverter and get one of these:
https://www.amazon.com/Trianium-Charger-Chipset-ENBL-Macbook-Chromebook/dp/B0711BK418/ref=sr_1_2?s=electronics&ie=UTF8&qid=1519226924&sr=1-2&keywords=usb-c+car+charger+macbook
It is pretty silly to take 12V DC, convert it to 120V AC, then convert it back to 20V DC for charging. Now that cheaper DC chargers are available and devices are standardizing on USB/USB-C charging an inverter makes less sense.
Contrary to popular opinion, grinding one's week or two supply of coffee prior to the trip & storing the ground coffee in an airtight container stored in the fridge, does not always result in less hair on one's chest. ;) In fact, less noise in the camping area at O-Dark-30 may lead to more courage later in the day. :p
Using a hand crank grinder so early may discourage vigorous hiking in the AM as the hand cranker may be worn out from the effort. A rock mortar & pestle produces a grind with more flavor released and one need only pour the boiling water directly into the mortar and drink directly from the mortar for a truly primitive beverage experience.
ps. Just kidding. Here's grit in your teeth.
Vic Harder said:
I had a cheaper version. Useless. Have you been happy with this one?
Very happy although It doesn't have a lot of mileage on it yet. Tried both 110v and 12v and works great. Slap in the batteries, plug it into the power panel and crawl into bed. Good to go by morning.
Timothy McGowen said:
Have you checked https://www.bhphotovideo.com
I have bought chargers for several Canon's and GoPro. They work great. Several brand have exchangeable plates for different batteries. I got a dual battery charger.
https://www.bhphotovideo.com/c/product/837092-REG/watson_d_1517_duo_lcd_charger_with.html
Many similar, cheaper versions on Amazon.
Woh! That looks great! Thanks
I have tried several cheaper units and been less than satisfied. I may give this one a shot!
