Bill D
We are getting to that time of year again. Our nights are starting to drop below freezing. I want to continue to use the camper in the fall, but I don't want to do a full winterization each time. I plan to drain the water system after each use as I always do, but I'd like to run a bit of RV antifreeze into the pump.
Have any of you broke apart the existing system to do so, or added a 'T' to add antifreeze to just the pump without having to introduce antifreeze to the water holding tank?
