pvstoy
This flatbed Hawk did not come with roof rack tracks. I want to do Solar on the roof. Looking at the Yakima 72" tracks ~$485.00. Is this the length FWC uses?
Looks pretty straight forward install. I see screwing directly into a aluminum beam in roof or using Yakima inserts into the beam since the aluminum frame is hollow. Then goop everything up well for leaks.
Option 2 would have ATC or FWC do it for me.... Any insights? Could be easy for them to locate the rear flood light wire location at the same time...Hum.
