DLN
After seeing the picture of a mini dinette posted by Stan in what appeared to be a shell camper I started taking a good look at the possibility of creating one in our Eagle. Turned out it was doable though with a few drawbacks. The trade off for opening up the camper window and having seating with the main isle open, not to mention a very sturdy table, is the loss of storage space. We decided we could just carry more portable containers and use the cab of the truck if we need the space. This set up is workable in the smaller camper but would work great in the larger 8' plus campers.
I cut the couch cabinet down to allow for 23" of foot space and two approximately 18" x 19" seats, just about the size of a typical dining room chair. The rear seat has a back formed by the existing couch back hardware and will fold over to form a bench in the table opening. Unfortunately the other seat can't have a fixed back as it would always have to move to get in and out of the camper. I'm working on a portable/easy solution for that one but for the time being that's my seat and my wife gets the good one, there's always compromise with that limited space. Cutting down the couch cabinet forced me to change the access ports to vertical slides from the existing horizontal set up. The biggest issue with the table was resizing the table support. Since I don't weld, and I'm not sure that material would weld that well anyway, I cut a piece out of the middle of the tube with a sawzall and added 3- 3/4" x 3/4" pieces of oak inside and screwed the two pieces together. A rather brutal approach but effective. The table top was made by FWC (thanks again Chicali) and shipped here in two days. I couldn't get matching carpet as FWC has changed their color but will be doing that eventually. I'll also be adding a wall cabinet next the rear seat back after we field test the set up and can see how much elbow room I can steal from that corner. Here are some shots of the new Mini Dinette.
