Bombsight Build Thread
I didn't see the Thermal Pack (liner) in the options list. This makes a big difference keeping the inside a bit cooler in the summer (not as HOT) and definitely warmer in the winter. I did not order my Hawk with the Thermal Pack. After seeing it in use, I ordered the pack and installed it myself. There is an excellent "how to" in this sub-forum.
FWC charges for change orders. But, you have a 2 week old order so you never know...
Advmoto18 said:
Which generator are you planning on using to power the AC? I'm curious because I'm looking at different post-purchase AC options.
My generator:
Bombsight, Congrats on the order.
I placed mine two weeks ago. Almost same options but on a Raven. I have the 1500 All Terrain with the 5'9" bed. Wish I had the longer bed for the Hawk but will make do. I also ordered the AC, live in Florida and drive to Dallas (I'm from there) a lot. I will need it.
Good looking truck, mine is a 2014.
Thanks, Chris.
Bombsight, is that a factory back up camera? And if so, where did you order it? Looking at doing something similar instead of re routing the one on the tailgate.
Check out www.cubbycam.com
Step 2.....
6.5" Lift with 35x12.50x20 Toyo tires & Hostile Gauntlet wheels.
Question about jack leg heights ...
What is the max height of the bottom of a 2016 Hawk when lifted with the FWC jacks?
Can I get the HAWK on & off of a 2016 GMC Sierra with a 6.5" lift?? :unsure:
My bed sets 42 3/4" off of the ground.
Also, has anyone ever mounted large wheels on the jack leg feet?
If needed put blocks under jacks to increase height; rather than max plus extension of jack...add blocks at least until the wind blows it over! :D
That Sir is a "Don't mess with Texas" size truck! Supplemental oxygen needed.
Phil
Lol ... yea, she's pretty big. :D She said she wants to be an Earth Roamer when she grows up.
I had thought about the blocks solution but was hoping somebody would pipe in and tell me the jacks will do the job by themselves.
You should be OK. My F-250 is 38" from ground to bed. Otherwise use blocks. Don't put casters on legs. There was a post by Stan at FWC. The legs will have minds of there own which could damage the brackets and camper frame. Jd
Thanks, Longhorn.
I was thinking blocks might be best anyway. Using them would mean less extension of legs equalling less cranking (work).
I had reservations about using casters on the jack legs but you just made my mind up.
I'll be a true FWC owner come next week and pics of just a truck will be no more. :cool:
Don't use the blocks unless necessary, without the blocks you will be able to reposition the jacks a bit at a time just by kicking them in whatever direction you want the camper to move. Ron
Thanks, Ron. Nothing like baby steps!
On that note; how effective do you think these would be when positioning? ....
