Bombsight Build Thread
The wetsuit drying rack is a nice idea!
Put one on the front lift bracket, attach two crossbars front and back, tie a tarp over it and have an awning.
Likely other uses like hanging a lantern etc.
Thanks for sharing.
Thanks, 323 & Longhorn.
Wont be long before I have a couple more mods to view (Quick pitch shower and mold elimination).
Bombsight,
Do you have sketches or drawings with a material list for fabricating the wet suit rack?
I would like to make a couple for our camper. My thought is to modify the fold out direction and put one on each rear corner of the camper. I could then use a removable crossbar between them with an awning track attached to the wall above the camper door so I can easily and quickly hang a tarp and have an awning over the rear door.
I think that may be a lot cheaper than buying a rear door awning (I have looked at Fiamma F35 as well as Carefree of Colorado and a rear door awning is around $500 or more.
ckent323 said:
Bombsight,
Sorry, I don't. I just went to my local hardware store and bought some aluminum. It all just fell in place after that.
Here are a couple of photos if that helps any ...
Bombsight,
It looks like you used 1-1/2" or 2" square Al tubing and 1/4" x 1-1/2" (or 2") Al bar stock plus a solid block of Al for a spacer.
Is that about correct?
Is there anything you would do differently if you built another?
Regards,
Craig
1" square Aluminum tubing & Alum. bar stock.
Spacer is the same with stainless hinge and aluminum rivots.
Teflon washers at pivot points and all stainless hardware (3/8" bolts w/teflon lock nuts).
Cant see how I could have done better at this time. The hardest thing is matching all of the holes up properly. A punch is a must.
Looks awesome! Something like that would work great for waders to dry out. I would be worried that the wing nut would vibrate loose, if so would drilling a hole in the bolt and adding a small hitch pin keep it captive? Or just tighten and have a spare in the camper? You have done very well in your design, thanks for sharing!!!
Thanks, pv.
I have a spare or two in camper. You could use a lock washer but its something else to drop and loose. I don't think it's going anywhere if tightened well.
I thought about using something like this:
https://www.amazon.com/gp/product/B00GAZ5TLY/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
So Stoked!
Just got home from work and found the Quickpitch en Suite Shower on my front porch! :p
Surpasses my expectations in every aspect and then some. The aluminum is much thicker and more robust than I anticipated.
Heck yea!
Installed the Quichpitch shower today. Not an easy job but really happy now that its done.
8 second deployment. Gotta love it.
NIce!
What was the cost with shipping? Did you install it yourself? Wondering how it is attached?
I would like to put one on our camper. The pop up shower surround we have now is no good in even a light breeze so I have to jury rig bars off of the Yakima racks on the roof to support it using bungies
Thanks for the photos. Nice to see it installed on a pop-up. Am very curious about price and how it handles a breeze.
I had looked into making a similar overhead support to attach to our factory roof rack but a design that would work well with top either up or down & could be put up when the top was already up didn't come easily to mind. Already had a similar issue with the factory rear awning.
We bought a Zodi i.hut shower enclosure.
http://zodi.com/accessories/ihut-shower-enclosure
It has some similarities in design but is self-supporting. There are stakes to hold it down & attached to its ground cloth. I have put it together as a test but we haven't used it for a shower yet.
Project complete for now. Still want to make a fold up roof for the shower.
