Clear Screen Door Slider
OK guys, here's a simple solution to your problem, something Marty of ATC showed me several years
back. Remove the slider, measure from the edge of the window frame to edge of screen door and cut the slider to that length. Remove the (unscrew) the aluminum center vertical and remove center screen. Move the aluminum vertical piece over to the edge of the cut down door, drill two holes and re-mount. Re-screen the center section with plastic screen and you're done. Took about 15 minutes to do mine.
Thank K60N,
I did mine last night. It took me longer than 15 min. It was the first time I rescreened anything. It was a pretty easy upgrade. I like having the vertical divider moved out of the field of view.
Mike
I just ordered one, I get so damn mad at mine, especially when I forget to take it out before i drive happly off, or sit ot step on it as it lays on the floor of the camper and off goes another hunk of it!-Thanks guys. :p
Smoke
