0976claxton
Just experienced a similar situation last weekend while in the White Mountains. Voltage (as measured on my Morningstar PM 15) dropped rapidly from 12.6 volts to 11.x within one hours, causing the low voltage alarm on my propane sensor to go bonkers just as the toddler and wife fell asleep. Ended up shutting down everything, and replacing my batteries the next day in Bishop. The original batteries were only 2.5 years old, but were some cheap sealed acid batteries from BatteryPlus. I didn't bother to have them stress tested before replacing. I assumed they were the issue and just ended up replacing them with two bluetop Optimas . It was a bit of a knee jerk reaction. Spend more money, and the problem should go away, right? What I'm curious about is the bulk load comment. My controller previously showed over 14 amps going to my batteries in good sunny conditions (180w grape solar on top). Am I safe to say that this is an overcharging issue? Shouldn't the controller hold the charge at 12.6 or so?
As for the fan, I'll search this forum some more for the information, but while I'm at it here: what fan are you guys going with? Seems like some good circulation in the fridge would help with efficiency at some scale. Last weekend was extremely hot outside, so I'm not sure it would have helped in this case as the fridge was working overtime to keep my beer cold.
