Installing DC-DC Charger in 2015 Fleet FD
Jack
Nov 18, 2007
426
Portland OR
Edited after follow-on postings - thanks everyone. Most pictures have disappeared - I'll try and get them back in.
I installed a DC-DC Charger in our 2015 Fleet front dinette for two reasons: 1. The 2019 Ford Ranger alternator is “smart”. 2. I will soon switch to a Lithium battery and my Iota can’t be reconfigured for Lithium and replacing the Iota would be a nightmare.
A smart alternator is voltage controlled by the ECU, which, after charging the truck battery, usually keeps the voltage in the range of about 12.5 to 13.5. This is fine for normal loads which demand current and don’t care much about voltage as long as it’s reasonable. The load of a charging battery, however, varies with voltage.
There’s a good explanation at: https://www.redarc.com.au/alternator-vs-fixed-alternator.
The Iota outputs 13.6 V except when bulk charging. This is fine for AGM batteries, but Lithium batteries want a higher voltage to reach full charge in a reasonable amount of time. This is somewhat battery dependent. The LifeBlue batteries, according to their manufacturer, needs 13.8 V for reasonable charging. I want more than 150 Ah and only the LifeBlue (200 Ah) and the Renogy (170 Ah) lithium have a form factor that will fit in the front dinette battery compartment.
I chose the Victron DC-DC 30 A Charger over the Redarc and the Renogy. The Redarc unit includes an MPPT Charge Controller but it is 25 A and does not have remote temperature sensing (I couldn’t find it, anyway). The separate Redarc display only shows voltages. You would be better off with a simple V-A display unit from Amazon – or what’s really the best is a true battery monitor (go with the Victron). The Victron DC-DC Charger is 30 A and is monitored and controlled over a very reliable and robust Bluetooth Since I already have the Victron MPPT Charge Controller only the Renogy would be cheaper, by about $30. The two Victron 30 A units will set you back about $420 (+$40 for remote sense). Add $25 for a display for the Victron or Renogy. The Redarc, without display, is about $380.The Victron units are microprocessor controlled and also get over-the-air updates. The MPPT charge controller has the remote temperature and voltage sense (a separate Bluetooth unit) and this is planned for the DC-DC Charger. It will simply be an OTA update. Since everything you might want to know about the MPPT and the DC-DC are availbale via Bluetooth and my old Clipper Battery Monitor gives a quick status view of voltage and current.
The Victron DC-DC Charger and MPPT Charge Controller are much more capable than the Redarc and Renogy – you can even use 12 gauge wire to the battery on the MPPT Charge Controller since it has remote voltage sense and will adjust the voltage output to compensate for the varying voltage drop on whatever gauge wire you have.
The killer reason to go with the Victron DC-DC Charger – no need for an engine-running sense wire from the camper to the truck. Both the Redarc and the Renogy appear to need one. On the Victron, you set voltage levels (a hysteresis for on and off) to detect engine-running.
One caution on the Victron units. You need to be comfortable setting them up with the Victron App on your cell phone or tablet (iPhone or Android). As shipped from the factory, you will need to configure a number of settings.
Other notes on the Victrons. I went with 30 A. They are large – the case is the same as the 50 A units. The 20 A units are much smaller (and cheaper).
Wiring the DC-DC From the Truck:
Most recent campers should have similar wiring. I strongly recommend a circuit breaker for you battery such as https://www.amazon.com/gp/product/B07PBGMMNZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 . This also acts as a convenient disconnect switch.
  1. For the Victron, download the VictronConnect App for your phone.
  2. Replace the 30 A thermal breaker near your truck battery and depending on the wiring to the camper, with a 40 A (10 gauge wire) or 50 A (8 gauge).
  3. Check the voltage on the “Main Bat” terminal of your battery separator – it should be the truck battery voltage. If not, stop here and troubleshoot or get help. Label the wires connected to the battery separator with tape (“Aux” and “Main”). in case you have to troubleshoot.
  4. Unplug the camper from the truck or disconnect the positive wire to the camper from the truck battery (or from the auto-reset fuse). Open the circuit breaker or disconnect the wire from positive terminal of the camper battery and tape the end. If you have solar, disconnect the panels. You may be able to unplug the panel(s) on the roof, or disconnect the positive wire from the charge controller and tape the end so it can’t short out accidentally.
  5. Find a location to mount you DC-DC Charger. Unless the DC-DC has remote voltage sense or adjustable charge voltages, the closer to the battery or the thicker the wire gauge, the better. If you can do the math to adjust the voltages, you can use 10 or even 12 gauge wire with the Victron. NOTE: The Victron can get hot, so make sure it has air flow.
  6. (needed to modify this panel)
  7. Disconnect the wire from the “Main Bat” terminal of the battery separator. Connect this wire (or an extension to it) to the input on your DC-DC charger.
  8. If there are two wires connected to “Aux Bat” post on the battery separator, disconnect them from the battery separator and connect them together. One should go to a 30 A auto-reset fuse – you can leave the fuse in the circuit or remove it. Be sure to tape the connection. If there is only one wire, disconnect and tape it. The Eaton 1341A battery separator has a black wire connected to a spade post. Disconnect it and tape the end.
  9. Sorry, forgot to take before pictures.
  10. Connect the output of the DC-DC Charger to your battery. If the DC-DC is not isolated(most likely), connect the single common ground terminal to the battery. If there are two ground terminals on the DC-DC, connect them together and then to the battery.
  11. Reconnect the camper to the truck (or connect the camper wire to the truck battery). Verify that you see the truck battery voltage on the input to the DC-DC controller. If not, check your wiring – trace the voltages from the truck to find the problem.
  12. For the Victron, with the engine running, open the App and set your parameters for battery type and engine running levels. The default Bluetooth pin is 000000. (The Victron website has detailed instructions on setting up and using the App.) You can change the Pin now or later. For a new Pin, choose something easy to remember – like your birth date in 6 digits. Write the Pin on a label and stick it on the controller. Also write the PUK number on the DC-DC Charger on the label as well. The PUK resets the Pin code to 000000.
  13. If you don’t already have a circuit breaker now is the time to add it. Close the circuit or connect the wire back to the positive terminal of the battery.
  14. Measure the battery voltage. Start your truck again, and verify that the voltage at the battery is greater. With the Victron, just check your App to verify the DC-DC Charger is charging the battery.
Wiring the DC-DC From the Iota
My Iota is AGM only, so I wired it to the DC-DC Charger as well. When I switch to a Lithium battery, the Iota will still do the job.
  1. Open the circuit breaker or disconnect the wire from positive terminal of the camper battery and tape the end so it can’t short out accidentally.
  2. The positive wire from the Iota went straight to the fuse block. On my Fleet, I could, with some difficult peering into the warren of wires at the bottom of the cabinet, trace it to the fuse block. (Unscrew the fuse block and pull it partway out to see behind it.) It was the lower of the two white wires coming into the input of the fuse block. See pictures.
  3. Disconnect this wire. Connect the camper to shore power and verify that you have 13.6 V on this wire (make sure the 120 V circuit breakers closed). Disconnect shore power
    (Bottom wire already removed).
  4. Add an extension to this wire to reach the DC-DC Charger. Connect it to the positive terminal, along with the wire from the truck alternator. Note that when connected in parallel, the Iota will also be charging your truck battery at 13.6 V. I actually wired the two inputs to a relay activated by the Iota. It’s not needed, but it was, easy, cheap and accommodated my sensibilities.
  5. Close the circuit breaker at the battery or connect the wire to the positive terminal.
  6. Measure the battery voltage. Connect the camper to shore power and verify that the voltage at the battery is greater. With the Victron, just check your App to verify the DC-DC Charger is charging the battery.
With equipment that I might need to get to (and who knows what changes I might want to make later), I have connectorized all of the wiring to the front panel. This included terminal strips to cleanup the ground and 12 V wiring connections. I also replaced the screw with a nut and bolt on the drawer track so the track can be installed after attaching the panel. When the camper was new, I used a piece of thin aluminum flashing to wedge the drawer end of the panel past the weather stripping around the door. Over time, this became much easier. The drawer track, on the other hand was always a PIA.
Thanks for the thorough write up Jack.
I just finished wiring up my Orion-Tr 12|12 30 today on my '13 Tacoma and '17 Fleet. It's charging a Renogy 100ah LiFePO4 battery, that floats at 14.4v. The Tacoma has a 130amp alternator.
On the test drive today on the freeway I had the Victron app open, and I was watching the voltage and charge status. Every few seconds the input voltage would drop to 11.6v and trigger the input voltage lockout (set at 12.5v) turning off the charge. If I disable the input voltage lockout, it keeps charging but the voltage is mostly steady at 11.6v and going up and down.. So, I'm thinking my alternator can't handle the output and I need a heavy duty alternator, or I bought a too high an amperage DC/DC charger. I could drop down to the 18amp version.
What are your thoughts?
Is it possible that the truck battery is failing? What’s the resting voltage of the truck battery? Also, what’s the truck battery voltage ignition on, engine not running?
Dean
What gauge wiring do you have between the DC-DC and the alternator? It sounds like your wiring is a little light and you are experiencing some voltage drop when pulling 30A. Can you set the charge current to 15A for a while and see if it works OK?
Are you using the factory defaults for engine shutdown detection? The factory numbers didn't seem right, but my attempt to do better didn't work. I reset to factory and my DC-DC appears to be doing the job. However, I have not taken a close look - the battery gets charged while driving, but the MPPT is also doing its job. Next trip out, I'll disable the MPPT.
The Victron does not display or limit current so I assume it's 30 A unless the source is unable to supply it.. (I love the "Demo Library" feature as I don't need to be connected to a real DC-DC to see what I can do.) Are you able to lay your hands on a DC clamp multi-meter and see how many amps just before the shutdown? And what's the voltage at the battery? Um, I suggest you don't do this while driving...
I didn't realize the Victron doesn't display or let you set the charge current. That is a bummer.
I'm running 10 awg and I know that is not enough. You can't adjust the current on the Victron.
Dean
2 year old Northstar engine battery that I keep maintained. Resting voltage 12.9 volts. Ignition voltage 12.4 volts.
The factory LifePo4 defaults don't match what my battery states. Factory: Abs 14.2v, Float 13.5v. Renogy battery: Abs 14.4v, Float Disabled or 14.4v.
I have tried both settings with the same results. I have also turned off the lockout, but I'm afraid I might melt my alternator.
Assuming 15' each way from the camper to the alternator with 10AWG wire, you will be dropping around 1V at 30A. What is the alternator output voltage at idle? It should be > 13.4V, in which case the 1V drop would be OK. Maybe there are some bad connections in the path? Or do you still have the 30A circuit breaker in the loop?
I do have a 30amp fuse on that 10awg wire running from the engine battery to the charger.
Alternator voltage at idle is 13.8 -14.2v.
I spoke with high output Mechman Alternators to get their point of view and I spoke with a tech at Victron. Victron will be putting out an adjustable amperage setting in the software in the future (maybe). This 30 amp charger actually takes 40 amps from the alternator to account for loss. Yes, I do have loss in my current wire gauge, but it's not that bad. Everything is pointing to the fact that the alternator is underpowered at 130 amps.
Well then your 30A (output, >30A input) is likely tripping the 30A breaker, which then resets.
Your 130A alternator should easily deal with a 30 - 35A load. I seriously doubt that is the issue. It seems much more likely that the fuse/wiring/splices are the issue.
I just put in a 40 amp fuse and it's no longer dropping down to 11.6v. Seems to be working fine now.
I'll upgrade my wiring next.
Thanks for all your help everyone.
When I initially installed my orion it was a little finnicky.
1. I would make sure the input voltage lockout settings are set correctly as the original factory settings in the victron software did not align with my truck's battery settings.
2. I used 6AWG and bluesea 60amp breakers w/Anderson powerpole connectors. After initial install I did notice I was getting some inconsistent values in the bluetooth application and it turned out to be some loose connections in the powerpoles.
3. I would also check with Renogy to see what their recommended charging profile is for their battery. I have a battleborn battery and they provided me with the recommended charger settings.
Hope this helps.
-Luke
As you probably saw in the manual, Victron recommends a 60 amp fuse or circuit breaker. I used a resettable CB in the engine compartment so I can disconnect when putting a battery charger on the truck.
Ran 4AWG back to an Anderson connector and then 6AWG to the Orion and the batteries. I'm seeing about 33amps outputting to my camper batteries, at least until the Orion gets too hot and derates. These Orions get red hot, I'm going to install a blower fan on a thermal switch to blow some air on it. If still too hot I'll add a vent to get better air exchange in the cabinet.
One last thought, did you wire to the truck battery or directly to the alternator? If you are going directly to the alternator and it is trying to be too smart it might be throttling itself.
Dean
Did you replace the trolling motor plug with an Anderson? I'm trying to plan a dc-dc charger upgrade before a LiPO4 upgrade.
I ran my 4AWG to an Anderson plug and then new wiring into the camper where the dc2dc is mounted. It was too difficult to get to where the factory wiring entered into the camper as it was behind the water tank so I just left all the old wiring in place from inside the camper out to the trolling plug. I did have a problem with the marker lights no longer being grounded so I connected the old ground wire exiting the trolling plug to the truck. There’s probably a better cleaner solution but everything works.
Some info to add to the OP's comment in first post:
"The killer reason to go with the Victron DC-DC Charger – no need for an engine-running sense wire from the camper to the truck. Both the Redarc and the Renogy appear to need one"
Don't need to run a separate engine-sense wire if you already have other kinds of disconnects. I'm using a Renogy, just added a jumper off the positive wire incoming from the engine. From previous installation config, already have a toggle switch to disconnect at the DCDC and an isolator at engine.
I added a thermal sensor to my system, that trips a powerful fan to cool the DC-DC charger. I get a consistent 360W out of it.
