rando, can you revisit how you set your BMV and MPPT controller to self-limit charging to 90% or so?rando said:From the first picture - 13.61V @8.5A, it looks like you have your absorption voltage on the charge controller set to 13.6v (there is more solar power available, but the charge controller is choosing not to use it). In which case the solar is doing what it should, get the battery up to 13.6V and hold it there for what ever your absorption time is.
If you want the solar voltage to go higher than this, then you need to raise your absorption voltage in the charge controller settings. That being said, if you get the battery up to 13.6V, then you are at 90% + state of charge, so you should be fine.
It is not that precise - when the camper is parked for a while, I set the absorption voltage to 13.5, absorption time to 10 minutes and float to 13.2V. Based on these measurements from powerstream and my experience 13.5V (3.375V per cell) should get the battery to somewhere around 80 - 90% SOC. This seems to be a better place to store the battery than 100% SOC.Vic Harder said:rando, can you revisit how you set your BMV and MPPT controller to self-limit charging to 90% or so?
13.2V is the normal resting voltage of fully LiFePO4 battery, so that is what I would expect to see first thing in the morning.buckland said:Thanks Lars. I had changed the absorption to 14.3 as seen below and the time at 30 minutes. I think I will increase the time to an hour. (kinda feels like I'm just jiggling the butterfly valve on the old chevy... see what happens!)
Attached the settings and the monitor this AM... Voltage still only 13.2
OK, that's some interesting research. I wonder why Battleborn recommends that the absorb voltage be set to 14.4V (see post #2 in this thread). I recall something I read on their site which indicated using a 30 min/100AH Absorb phase actually helped with balancing the cells.rando said:When we are using the camper, I up the absorption voltage to 13.8V, which based on the above measurements should get the battery to 99% SOC. There is almost no advantage to going over 13.6V - 13.8V, taking the battery higher just increases the likely hood of unbalancing the cells,
