leadsled9
Contributors
That is what I was thinking. If I had a diesel in which there are a lot more parameters to check out and monitor I could appreciate the edge but with a gas engine I'm just not seeing it. I mainly w to watch trans temps and instantaneous MPG off the top of my head. Leadsled9 how about a little more input on your suggestion for consideration?
The Edge CTS is more expensive than the Scan Guage, but it has proven to be much more reliable and accurate. You might save a few bucks on the Scan Guage and it might work out just fine for you....but how much is your engine worth? Is it worth the risk? Only you can answer that question for yourself.
