OK Vic, I'll take a shot at these . . .
Vic Harder said:
1) If you look at this pic of the rear wall where the propane box is going to go, you will see that there is a double section of framing back there at the bottom. The box fits above that. Is it normal for the box to be sitting up above the floor by that amount? It would leave room for the water tank drain line to go underneath.
My hawk has the water heater located there, and it is double framed although the heater doesn't go down that low. I don't have a photo of the framing, just some photo evidence of double tubes. The drain is centered two inches up the wall, and runs through the center of a 1" tube. Someone still managed to poke a hole in the drain when attaching the floor pack, kinda doubt it was the factory though.
Here's a '99, no factory furnace or water heater, propane locker is up high on drivers side. There is an external storage locker in place on the rear wall, double framed on bottom.
1a) That picture is upside down. How do I flip that around?
It's an iphone thing,
this might help.
2) There was a purple wire taped up high on the rear wall. Flood light?
3) The green wire goes as far as the sheet metal siding, but not through. That could be flood light too.
The floodlight wiring is green, and goes to both sides of the back wall. The porch light wiring is red, and goes to one or two walls. There is also a black wire for ground, mine was simply connected to the rear wall framing. I think red is used a few places, but the other primary red/black pair would be to the roof for the fan and interior lighting. That wire runs up the front behind the lift panels, pic in question #5.
4) This pic is of where the fridge is going to go. Looks like it has a spot where the fan is supposed to mount. That won't work for my TF130. I'm just going to cut a 4" or so hole at the top right, where the hunk of white plywood sits. I will have to cut one of the aluminum supports there. Thoughts on that?
To my eyes, that looks to framed for a furnace, the black plastic inserts form the vent hole. I believe in a shell you could order a furnace, but no fridge.
The white ply is an insert into the structural C-channel around the top (Remember my "Sideboards" as I referred to them in my build). It looks like a wall frame member already interrupts the channel, but I would think a bit before cutting into it.
5) These pics are of the "wiring channel" near the front, driver's side of the camper. The orange wire went to a 12v power socket, the red and black with the yellow connectors on them were just sitting here. Looks like they MIGHT be the end of the solar panel wiring. Ideas on that?
I think these are roof fan/light wiring. I don't know that solar pre-wiring existed in 2005, but not sure. The solar install on my '04 had blue/black wire pairs, I'm pretty sure FWC installed them., but it may have been a post-delivery retrofit.
Here's the mess that someone created in mine (Don't show this crap to anyone! Promise?)
Did I win the big stuffed animal?
