BBZ
Thanks.. couldn't do it without a garage.. would be so hard with the unpredictable spring weather around here..JDeanP said:Jealous of everyone with a garage!
Keep up the good work.
Nice backsplash! I'm not sure, but from the pics it looks like you are using 3/4" plywood? If weight is an issue for you, consider using 3/8" Baltic Birch. Strong, light, nice finish.BBZ said:Kitchen mock up .. will add stove
thanks for the info..Vic Harder said:Nice backsplash! I'm not sure, but from the pics it looks like you are using 3/4" plywood? If weight is an issue for you, consider using 3/8" Baltic Birch. Strong, light, nice finish.
Thanks, Russ.. Wife's idea on the counter top.. Pretty happy with the build at this point, a few more details on the inside and it will be time for the sideliner.. its almost complete, hope to put it on next weekend..CougarCouple said:Morning BBZ
Really like the build out counter section and especially the map top.
Russ
Thanks, I was thinking about that with the diamond plate as well.craig333 said:Nice work. Never seen the barn wood accent look before. Interesting. The countertop, i may have to steal that idea!
You may want to extend the diamond plate to the sides. Mine took a surprising amount of weathering before I did that.
Its looking good! Question regarding the conduit lifters... How did you mount the bottom of the conduit lifters to the camper?BBZ said:Getting close .. roof attached .. wiring complete (and it works ..phew) ..
