We're still watching and enjoying!
Great, thanks. More to follow:
I've got the majority installed now. Still outstanding are lights, the drop sides, and a bracket for the fuel filler. My bed was a custom length 7.5' and they sent the wrong drop sides (8.5') so I need to cut them down and drill new hole placement for the pins, otherwise I would have already wrapped that up. As it is I got cooked by the pleasant sunny day in which I forgot about sunscreen so I called it a day. Working casually solo this was about 8hrs of work to unbolt/remove the other bed and install this one to the point you see.
Other bed stripped and unbolted, ready to remove:
I managed to squeege my truck into the garage next to the camper build (BARELY, I had to climb out the window) so I could use the ceiling joists to ratchet off the old bed:
Cab and chassis style ready to get the mounts installed:
Hard to see in the picture since I already touched it up but there was a gasket on the bottom edge of the stock bed that had rubbed through the paint, so if you're planning to do a flatbed have some touch up paint handy to paint over the possible bare metal (I didn't and had to stop to run to the store). Also one of the mounting brackets:
My headboard was setup for 9" drop sides when I got it so I had to drill another hole and flip the bracket to work with my 12" sides:
Other than sides/lights/fuel filler as mentioned above its more or less done for now. I'll eventually build a custom rear bumper that will come out slightly past the flatbed but I've got other things to focus on for now:
Also this bracket will be getting installed behind the front bumper as well for a future addition:
