Definitely run some wiring.
Since the upper main rail is damaged I am going to check some prices and possibly run 2x6 channel up there instead of what the original stuff is. That leaves tons of room to stuff all kinds of electrical, speaker, etc wire.
Lights on all three sides.
I'll start looking, I have some catalogs from places - any suggestions on specific lights?
Fans.
I figure one up top and one in the middle should do the trick
Solar.
There is quite a bit of room under the overhang upper bed part, a slide out solor panel will fit nicely there. It won't get sun when I am driving but will when parked. Maybe half slide out solar and half slide out drawer for storage.
Anything you can think of that might possibly be done at some point in the future. Not much work even if its never used but it'll never be easier than now.
I don't plan on using staples like factory, I will either use screws or rivets. Either way they will be somewhat removable so if I really wanted to I could take it partially back apart.
Made a dump run today, the only thing left now is the aluminum frame
Hoping to raise the window on the side and then squeeze the sink and stove under it. It will all come together once I fit it in my truck.
I gotta check and see what that replacement pop up material is going to cost. Tight on funds right now so it might sit for a little bit till I can find some work to pay for toys
