Removing Flexible Solar Panel
alano
Jun 18, 2013
255
Silicon Valley
I did it. Took about an hour.
Here's the story: One of my Renology panels has been flakey for a long time. I thought it was connections and made and remade changes. Finally I stumbled on to the fact that the panel essentially stops working when it gets too hot. It will work early in the morning but quit as the temperature rises. I was able to replicate this was a panel fault by covering my other panel, checking for 0.0 amps on the controller then spraying water on the offender and finding 1.6 amps surging into the batteries. Over the next 15 minutes or so the current tailed off to under 0.5 amps and I stopped watching.
Haven't called Renology yet but figure they want the panel back for warranty replacement (though I cut the MC4 connectors off so not sure what they'll say). Even if no replacement, I wanted it off the roof.
Started last evening with an X-Acto chisel blade to cut into the Sikaflex I used to glue the panel down. Had a vague idea of getting a start and then using fish line to "floss" through the glue line. Scraped a little paint on the roof as expected but figured it was the price to be paid. Blade just wasn't very long and glue line pretty wide after all so stopped after working about a foot along the perimeter.
Woke up in the middle of the night slapping my forehead with the solution. Wood shims! No paint scrapes, pretty long and I have a bunch of them sitting on a shelf. This morning I used a handful of shims and a rubber mallet to hammer, shove and wiggle the shims between the panel and the roof. Took about an hour. Best part is I didn't get any splinters though gloves would have been a good idea. Now I have to get the rest of the stuff off the roof but I figure a plastic scraper might work pretty well.
Just a word to folks who are planning to glue panels to their roof: You really don't need a lot of glue. A thin bead around the outside to keep the elements from creeping in is plenty to hold that sucker on the roof and if you have to remove the panel at some time it will be way easier than having glue lines through the middle.
On the Renology web site it looks like gluing them down is a recommended application, but I've been talking to a friend who's a solar engineer (in preparation for buying a camper with solar, either preexisting or we'll put together our own system) and he strongly recommended a setup with air circulation behind the panels.
Here's an interesting link to an airstream site that talks about applying "Supertherm," a ceramic coating that limits heat gain, to the roof before attaching the panels.
http://www.airforums.com/forums/f448/flexible-solar-panels-opinions-102239-2.html
Sounds like you may have a warranty issue, but I was wondering about gluing panels directly onto a hot roof, and your post got me to searching online.
DoGMAtix,
Apologies for a quick hijack, but I noticed you linked to Airforums. Are you an Airstream owner? Send a PM if you want.
Steve
Alano,
That is good information. Seems to me we should have a pinned Post that organizes all these flexible solar panel
experiences under one heading.
In the four Wheel camper discussion Don C has been discussing problem with 2 out of 3 bad panels. Post title "Electrical confusion".
I will PM one of the moderators and ask.
Alano - I need to remove two panels this weekend. Do you think it would have helped any to get the edges up, spray adhesive remover under the edges and let it work for a few minutes? I spent a few minutes working on mine tonight and worry that I may have used too much adhesive. Its only when you try to take one off that you realize how little is needed to install.
If they become to much of a hassle to remove, Renogy has told me I can just glue the new ones atop the old.
I checked the data sheet and emailed the good people at Sikaflex and, as a polyurethane, it has no "antidote". Mechanical means are required. Your adhesive may have an antidote. If I had a remover / softener, I would have tried it.
Alan
DonC. I removed my panels that were glued with semi-permanent 3M by starting with a box cutter, then wedges as Alano suggested along with a 18" kitchen knife. Long kitchen knife was the key. I'll have to clean up the residual glue on the roof once I receive new panel.
Hi fellas,
Just a tip... for anyone who is installing these flexible solar panels, I got an idea from a post over at expo. Basically, glue the panels to a sheet of aluminum first (thin sheet of aluminum) and then attach to the roof with screws. At least this is my plan. I can keep the panels to 0.5 inch thickness, and they are removable anytime. This wont work if you want to glue panels to your camper but it works good for my plan.
Attaching to a sheet of aluminum sounds like a good idea. I was thinking of making a rectangle out of tubular aluminum and screwing the panel to it, then attaching it to my roof racks (or maybe just L clips) such that it could be angled to the sun as needed, or not. The wiring would be contained inside the rectangle. Not sure if this would be strong enough to fight the wind while driving.
I have Yakima tracks and looked at creating an aluminum platform for the flexibles. My calculations showed that it would not be much lighter than just using a rigid panel.
