Yes, changing the fuel filer is a good suggestion. To this point, I have changed it four times. Each time the used filter is full of crud. It seems like the amount is gradually going down. Last time, the engine ran properly for about 120 miles before starving for fuel. If we stop, as in seeing a sight, and shut down, the engine runs better for a while, then goes back to the old problem. I figure what is happening is the filter contamination settles off the face of the fuel filter element when the truck sits still with the engine off. I changed the filter this morning and used a cooking pot to pour the filter contents into, so I could check what is there. It is a fine very dark brown substance that quickly settles to the bottom of the pot when I swirrel it around.
We are presently in the RV park aboard Fallon Naval Air Station. (I am sending this from the base "liberty" cennter.) Last night, the temperature for sleeping was nice. We were awakened early by fighters taking off to start their day of Top Gun school. That was quite an alarm clock. I saw some of the pilots at the base Subway shop later in the morning. These are sharp dudes. R wants to stay here an extra day to take in some groceries for the planned off road venture with the Oregon California Trails Convention pre-convention trip. We are planning to follow the Donner route around the Ruby Mountians. We have been advised to leave our camper parked the first day as the planned route is over rough trail. I have been assigned to ride with a prominent Mormon historian, which will be quite a privildged. The guy is about 80 and knows the remote areas of the western Utah, Idaho, and Nevada desert better than any other man alive. He has written and lectured on the subject, so I will be more than happy to leave our rig parked for the day. The road and trails on the second two days are suppose to be less challanging but I will stick with the historian if I can.
Tomorrow, we are looking at driving Route 50 across Nevada. I plan to stop by the Fallon Ford dealer and buy a regulation Ford fuel filter. The AutoZone is across the street where I also plan to buy another cheapy fuel filter. Incidentally, there is a trick to changing the fuel filter which requires a little tool to release the "quick dis-connect" couplers to the fuel filter. There are a couple of clips plus four clips inside the quick disconnect. The little tool slides on to retract "fingers" that snap in place. The trick it to apply a touch of grease to the tool before inserting it and a little grease on the filter tubes before sliding on the connectors. Then the connector can be gently pryed off with a large screw driver. As I have become rather expert at this procedure, when I get back to Alabama, I should take some pictures of how this procedure is done. One never knows when you might need to know.
We stopped at the Donner Camp east of Truckee and took some pictures. It is so sad at that camp site, even the birds do not sing. Down town Truckee is a tourist trap but a new National Forest Service center has been built up by the highway which will be helpful to those wishing to scout the trail of the Donner Party through the area. It was not quite open yet, but close.
We are topped off with water for the Loneliest Road Route 50 and no one knows where we will camp along the way. Several years ago, I spotted two mountain lions crossing that same road, which made us a bit cautious about sleeping out under the stars. I have my old Model 10 with me this trip (as if it would do any good). Later ... John D
