Yeah... I just now put a link to this thread in the first post of the roof lifting helper shocks thingys thread.ETAV8R said:IMHO I think most of this discussion could/should be in the roof lifter thingy's thread.
Thanks Mark!MarkBC said:Yeah... I just now put a link to this thread in the first post of the roof lifting helper shocks thingys thread.
Rob, sounds like you should have room to use the 36" #40 struts.buckland said:I appreciate the input and advice from all....it is indeed a topic which effects many would be DYI (which is most FWC folk) installers of struts.
It makes sense to me as well, that owners of older model FWC who don't have pre-installed mounts or rivnuts should be able to adjust where they mount the hardware so that the strut will fully extend. On the other hand I do not want to be dissatisfied with the lift assist after installing the shorter strut either.
The distance when opened is 29 ½ " vertically. It is indeed 40" from the clamp hook on the roof (besides which one mounts the top bracket) to the center of the wall above the rear door. (usable horizontal space = 60" above both door and roof edge horizontally).
Hey Frank, I'm Rob and Buckland is my town's name! But I kinda like the Mr. Buckland...sounds like I'm the mayor!Still sounds like you can place the 36"/40# struts on your camper if you have just some simple tools.
Here is a thread about the FWC repair to install reinforcing plates on those that had the original mounts.Casa Escarlata Robles Too said:One question, do the FWC campers now come with per installed strut mounts?
Rob what Brenda told you now makes sorta sense, but you should be able to use the brackets from Suspa to mount the struts,I think.buckland said:PS
Brenda said the campers come with the "rivnuts" now which are tapped into the frame and are then capped and then can be used to mount the brackets ( with ball socket) if one wants.... so yes they are pre measured to fit the 36" or the 40" struts depending on the model (see pdf I attached previously)
I have a solar panel, 4 Yakima bars, and a basket case on the roof of my Grandby and use 2 internal 100# struts to make lifting it easier. When the top is loaded with kayak and other things, I lift the rear manually and use the crank to lift the front. The front can be raised manually when loaded but it's a pretty good lift. The internal struts take a lot of strain off the hand crank.buckland said:I have used one since I got the camper ... it works great. With the added weight of the Yakima system, gas tanks and canoe you will hear the crank strain under the weight... it is a very light weight aluminum gear. If the roof was stock it worked great. This isn't the case anymore. I used the tripod I removed to set up a solar panel so that I could place it in the sun...camper in shade; that's another string posting.
