la_morris
Thank you all for the feedback. Very helpful!
I was a little confused about the whole "speaker lift" issue until I found this post - thanks Bob for this very useful post. I have ordered a speaker lift from a Canadian dealer for $115 and free shipping.BobM said:Here's a video I did today showing how easy it is to lift the roof with a Pro Audio speaker stand and a power drill. I don't have lift struts on my rig and don't need them.
The stand can be purchased here On-Stage SS8800B+ Power Crank-Up Speaker Stand | Guitar Center Just drill out the tripod because all you need is the pole. Save the rubber feet from the tripod to put on the ends of the pole
Buckland, Thank you, thank you thank you! I have been measuring and figuring the past few days with plans to add the struts from the kit from 4WC. I also tried asking 4WC questions in several different forms trying to explain to them that I didn't think the install was going to work as their instructions describe without moving the front catches. Same as you all I could get is terse answers telling me the kit was right and no actual customer service. This post and your instructions that follow are going to be very helpful so I just wanted to pass along my thanks, I'm grateful you took the time for the photos and instructions. I guess 4WC will take your money and that's the end of their service.buckland said:Well, after purchasing the hardware from 4 different sources and buying the 40" struts from FWC, I started all the pre measuring to be sure all would go as planned. I have found that the 2011 Eagles have 2 issues:
The front roof clamp latches need to be moved out approximately 3 " for there to be enough room to accommodate the 40" strut i.e. the top of the strut where it is attached to the roof needs to be right where the latch is (wouldn't ya know). On the back wall above the door, I believe I might have to remove the drip edge and cut a few inches off each end.
I have tried to ask FWC for info but received only one word answers... really.
So my questions are to 2011 Eagle owners have struts or to anyone who has moved the latches for some reason, please let me know anything to avoid. Where does one get the gray sticky putty tape that goes beneath the clamp and is the roof latch also cemented to the roof? If so what kind would I user? Any other advice would be appreciated too.
I will move the bottom clamps over using the left screw holes for the right screws...avoiding 2 extra drill holes.
Sure hope all this will be worth it in the end.... in for a penny in for a pound.
Hey Northbynortheast,Northbynortheast said:FWIW
Suspa gas springs are way overpriced. I just bought a new set from Gemini gas springs in Canada. Ordered from US. About 25% of what the Suspas cost. $160ish ca? for four.
Hey Buckland, hope its not to late to revive this thread. I'm looking to add some lift supports to my 2010 Finch and have been using your PDF as reference for an install. You mentioned earlier that the rear panel didnt pop in and out as easily prior to your fix of moving in the rear roof strut supports. Should I not use the 40 inch jig method to determine the placement of the brackets? Any and all advice is appreciated.buckland said:Hello again... just out of hibernation of New England and about to head to Kentucky with the 2011 Eagle on the 2001 Tacoma. I had installed the roof lifts last fall and then had to wait. A week ago I was able to load the camper and see how things held out with the winter cold...whoa a cold one here. I tried the roof lift and it was not nice. I used the factory install method ...made a 40" template arm so I positioned the arms correctly ( recall the front roof clamps had to be moved out to get the right lift position). The front worked great but the back, even though I used the FWC 40" template for the 40" required lift supports, the 'stretch was too far out . The directions received from FWC was to put the lift bracket ball up against the roof clamp.I did that and speaking from a 2011 Eagle stand point that is not right. I decided the geometry of the lift was wrong... I could feel it did not have the lift needed at the right time of the radius swing of the lifter. I decided to be yankee conservative and move both lifters in on the roof 1.5" so that I could use one of the same drill holes. Sure enough ...wow... a huge improvement. The roof lifts with only a push instead of needing the crank. And most importantly at the top of the arch... it gently allows the panels to pop into place... no hard snap. I am very happy. I did plug the extra hole with a screw and silicone. So we are off to KY and then Virginia George Washington National Forest and on up to PA and then home. I just wanted to let anyone who decides to add lift supports to their Eagle (needing the 40" 30 lb supports) if they need help just ask and I can give what info I gained in the process.
