Idahostat
Hello
Can some one point me to a list, reference for the dimensions of the models ( I get that the length varies ), trying to determine width, base to shoulder ( trying to determine size for fitting to a utility body, found a set of images from expedition forum from someone who has done this, the man had the skills and tools to modify his recycled utility body and he already had a Alaskan to work from ). Depth of standard box on truck varies depending on year/decade of manufacture. Utility bodies varies by Mfg for different markets and DRW or SRW.
Alaskan does not have dimensions other than length and wet/dry weights that I could find on their site.
If you have yours on a ___X____ truck is the clearance the same over the cab have you observed? Assuming you see and talk with other Alaskan owners.
Are you using a wind deflector/foil?
Terence
Terence
