Fleece as soft-side insulation?
I think the fleece material a good choice IMO as the moist air will not condense on it as the fleece doesn't conduct heat that well if at all.If attached as you have stated there will be a dead air space between it and the liner,which conducts heat/cold very well.I have some fleece laying around I may try soon in the bed area and find out if it keeps condensation from forming the liner in theta area.A cheep experiment.Everyones ideas sound good just need to figure which one fits my needs better.I don't want another thing in the camper I have to store or spend time setting up and then removing to drive away.I still like to keep it SIMPLE.
Here's my long-winded explanation -- stop reading when it becomes tedious.
The more I read about your fleece idea the more I am convinced it would be better than the factory material. However, it would not have any reflective properties, so there would be no gain from radiation loss. (As I am going to be using a Wave 3 (catalytic) heater saving the radiant heat would be good.) But I strongly agree with the following statement, so I am not sure how to best insulate the pop top.
The compactibility/foldability of the arctic pack approach (so it can be left in place) seems to me it's big asset.
Hmmm....I don't know how important radiant heat loss is in this situation. I'm not saying it's not significant (though that's my gut feeling), but I just don't know the answer. I know I've done similar analyses in college, but that was a long time ago...
Maybe somebody who works in HVAC already knows the answer, but I don't think the answer is obvious.
Hmmm....what about those emergency "space blankets" -- the ones that are basically an aluminized plastic sheet. They only work against radiant heat loss. I've never used one...but would one of those by itself really keep you warm on a cold night? I don't know...but I think that if radiant heat loss was big or significant then more clothing, etc., for cold weather would incorporate a reflective layer.
Whatever the importance of radiant heat loss from the camper in general, I don't think that the fact that catalytic heaters produce radiant heat means you need a reflective surface to contain their heat....unless the hot surface of the heater is pointed at the soft-side. Once the radiant heat from the heater hits an object that object is warmed and the heat is eventually transferred to the air. In other words, it doesn't stay as radiant heat for long.
The longer wavelength infrared will certainly be partially absorbed and re-emitted by the liner - fleece or otherwise - but not totally absorbed. There will be some radiative loss. It makes sense to me to add a thin reflective layer. I'm thinking something like a space blanket, although that would make crinkly noises, I suppose. I may be remembering wrong, but I have a vague recollection there is something reflective in the fabric FWC uses in the Arctic Pack. Or, maybe that's wishful thinking. It's not obviously there when you look at the fabric.
More about radiant heat loss:
Has anyone ever done the science-stunt in which a small amount of water is put in a vacuum (aka "Thermos") bottle with the lid/cap off and put it outside on a cold, clear night? I never have, but the water is supposed to freeze before the ambient air temperature drops below freezing because of radiant heat loss from the water to the cold, cold sky. The vacuum bottle is necessary to keep the water from being in thermal equilibrium with the air outside of the bottle.
Another example of radiant heat loss that I have experienced: When skies are clear overnight, frost can form on the roof of houses or cars even when the temperature of the air is a couple degrees above freezing. This is because the roof loses heat faster to the empty sky than it can gain heat from contact with the air.
I'm sure you're right that radiative loss occurs...but I wonder what the relative contribution is between radiant and conductive heat loss -- how much of each -- from the camper.
One reason why the answer isn't simple/obvious (and so would need a real analysis and be dependent on assumptions) is because the conductive heat loss (and convective if the camper is leaky) will increase when it's windy, but wind won't affect the radiation.
I think I'm gonna refurbish a large vacuum/Dewar bottle, mount it on the back of my truck, and camp in that -- that way I'll know I have the warmest camper possible!
The emergency blankets work. I do not know how much of them working is the reflective heat gain or the fact that you are trapping air by wrapping up in a bag. Could do a test, emergency blanket versus trash bag.
Good point. I was picturing all this radiant heat floating around the camper, but you are right, at that point it is hot air. (Sorry, I am really tiered.)
I think I'm gonna refurbish a large vacuum/Dewar bottle, mount it on wheels, and camp in that -- that way I'll know I have the warmest camper possible!
Today we were talking at lunch about some camper trailer in Alaska that had about 24'' of spray foam added to the exterior! It had one window and the door cut into the foam, otherwise it was just a big blob of foam.
Yep! Both Home Skillet and Pods8 have harnessed the POWER OF FOAM in their custom home-built rigs.
I'd luv to see a photo of that Alaskan foam-mobile.
I agree that it could turn out the radiative heat loss is secondary, but if it were cost-effective, using reflective material would certainly help with the total energy budget. There are actually some fabrics out there with a reflective surface meant for many uses, including clothes, but I don't have a clue how cost-effective they are.
I didn't know about these reflective fabrics -- I'd be interested.
When I think of reflective fabrics I can only think of a slinky dress on a Hollywood celebrity...or something Elvis used to wear, but I'm sure you're talking about practical fabrics.
Thinking about celebrity-wear, I just had an idea. How about covering the surface of the insulating fabric (whether fleece or arctic pack) with shiny silver sequins!
It would still be flexible and yet be reflective. That would be sooo cool!
But that sequin-sewing job would definitely be one you'd want to outsource to cheap labor.
Susan says she is definitely not available. :p You might want check with Ski3pin, Barking Spider and the Lady as to their hourly rates.
Have you found a source for a 12V LED disco light to go with the decor? :D
Here is one example, but since they don't mention a price, it makes me think it must be expensive.
http://www.afminc.com/thermoflect.asp
and another - again, no price on the page...
http://www.radiantba...om/temptrol.htm
Or, rob a bunch of pizza delivery people, grab those fabric insulating carriers and stitch 'em together :rolleyes:
Nice catch, HighZ. I checked out the site and they do an excellent job of explaining the three modes of heat transfer: CONDUCTION, CONVECTION, and RADIATION
Radiant heat loss is our biggest heat loss and aluminum foil reflects 95%.
Ummm...this can't be true, or it's misleading in some way. If this were true -- that radiant heat loss is the overwhelmingly major form of heat loss from homes/buildings then nobody would bother to put insulation in the walls of homes and modern walls wouldn't have thicker insulation than a few decades ago. Walls would be very thin -- just thick enough to contain a few layers of foil. Unless all the history of insulation has been a scam.
I think it's important to realize that these "facts" are presented on a website that's selling radiant heat barriers. I never believe someone who's trying to sell me something -- not without unbiased confirmation.
My statement was intended to be about campers, not so much houses. I don't think only a radiant barrier would be sufficient for a house. Reminds me of those emergency space blankets.
We use bulk insulation in houses to reduce heat loss from conduction. I used to do my own calcs for to prove energy efficiency for building permits and the formula went: Square Footage x Temp. Difference x U value (inverse of R value) = BTU's lost per hour. Take a 8' x 10' wall with R20 insulation with 70F inside and 30F outside: 80SF x 40F (70F-30F) x .05 (inverse of 20) = 160 BTU's. Aluminum frame windows are an example where conductive heat loss is fairly severe. Sometimes the frames are so cold, they hit dew point and condense water. FWC uses styrofoam (I believe) in the ceiling as a type of bulk insulation.
Convective heat loss can happen, but you need the air to be mighty still for the air to begin to circulate. I don't think it's that significant, but that's just my opinion. It's " not intended to be a factual statement " :LOL:
Infiltration can be an issue, but what the hey! I'm cracking my vents when I run my Wave anyhow. And when we open the door, well the interior gets an air change on the spot.
Radiant loss is interesting. Warm bodies emit long-wave infrared radiation that travels in a straight line. Thermal radiation is what we feel from the sun or a woodstove. You can store radiant heat with mass (you wanted a granite countertop in your camper didn't you?? :p ). Regular low-density insulation (fiberglass batts, blown cellulose,etc.) are very poor at stopping infrared loss. This is where aluminum foil can be very effective as a radiant barrier. The reflectix has this attribute and is also effective as a barrier against conductive heat loss due to it's insulation values from two layers of closed air cells.
For the record: I am not a reflectix dealer :D :D :D
Thanks for the link, I printed it out and read through it a couple times today. Very interesting. I tried the little experiment with holding aluminum foil up to your face, and it was interesting to see how fast I felt the heat, and how warm the heat felt.
So, two things-
a reflectix type arctic pack would be the warmest, correct?
my idea of doing an aluminum interior would be good radiant insulation, correct?
Well....I don't think it [mostly radiant heat-loss] is true for campers, either...but I don't have any facts on this, just gut-feel. And as a recently-retired professional researcher, I'm not a big fan of gut feel or guesses -- even my own -- as a basis for belief.
But -- I have an infrared thermometer, I know how to use it, and I'm the kind of guy who's liable to use it!
...And mine has a hair-trigger.
So, as an alternative to pointless guess-work, I'm going to perform some experiments!
I don't have an exact experimental plan yet, but I think the basis for the analysis will be the temperature of the outside of the soft-side. I think a typical experiment will consist of applying one type of insulation to one soft-side and a different type of insulation to the other soft-side (on the insides). Then, after a period of time to allow the external surface temperatures to reach a steady state, I'll measure the temperatures of the outside of each soft-side.
I'm thinking of testing/comparing these "insulating" materials:
  • Closed-cell polyethylene foam
  • Reflectix
  • Aluminum foil (household)
  • Fleece
- Mark
"Will research for food"
We (the home builder I work for) are using a form of insulated aluminum foil in the house we are currently building. Although we are only using it under the heated floor, not in the walls or the ceiling.
