Manfred65
Today she first installed the rear window:
It is fix which is important because in europe it is not allowed to place an exhaust under a window that can be opened or less than 12" from the side of a door or window. With this original window we were able to place the exhaust of our Truma furnace below it. The exhaust as last part of the furnace installation was our next step this day.
In the late afternoon we replaced the front wall of the camper. First we used the old wall as a pattern. In the corners below you can see the cutout which someone made to fit the Jayco on a Nissan Frontier ( "Navara" in Europe ).
placed the glue on the frame.....
screwed the wall to the frame....
and thats it :
I was afraid if everythink will come together in a tight fit. But we worked as straight ( or crooked? ) as the guys at Jayco 22 years ago! The only differences we had came from the material:
Originally there was 1/2" Ply, we used material of 1/3"+ !
You miss the front window ?! Because of the risk of "production tolerances" we decided to mount the aluminium cover on the camper before cutting out the window!
and thats it :
