Mpg report
2008 Nissan Titan with loaded FWC Hawk on it. I average 13mpg. Wish i could get 15, but considering i paid only $18k for a used loaded truck, i justify to myself that i just saved a lot of money that i can burn in gas.
2012 ford f-350 crew cab,4x4, 1500 lb. Granby , 6.2 liter . two lane , 62 miles per hour , 13 mpg , hilly curvy western wisconsin roads .
I just got back from TX to Alaska driving a 2002 [SIZE=100%]SR5 4x4 Access Cab V6 5-speed manual with fully loaded ATC Ocelot. I try to keep it under 65 mph. One interesting thing I found is that while driving slower and in the mountains (much of the time in 4th gear or lower) my mpg increased. I drove all over the [/SIZE]Oregon[SIZE=100%] mountains and got 20.5 mpg mostly at 45 mph or less from La Pine to Crater Lake and north west to Roseburg OR out to Bullards Beach SP on US101 ending at Crescent City Ca. I took US 50 from Carson City NV to Lake City CO I got around 19 mpg, great highway at about 55 mph with a tail wind. First day, I got 15 and 13.4 mpg from Plano TX to Salina KS on I35 into a head wind at 65 mph. Attached is my milage log.[/SIZE]
[SIZE=100%]In the Log for Canada I converted liters to gallons and used a factor of 0.8 for Canadian dollars to US.[/SIZE]
  • Alaska Trip.pdf
Just looking over your MPG log.Very impressive.
Also didn't realize your truck is V6 5 speed.
Mine is V8 auto 4X4,but I can get about the same MPG as you.
Usually about 16.Don't travel much over 65.
The far right column is a weight average milage based on number of miles (gallons x miles) / total miles.
FINALLY got my Hawk shell on 2014 Ram 1500 ecodiesel quad cab 4X4. Mild mods are lift/level, cold air intake, and muffler delete. Without camper 30 hwy/ 24 around town driving gently.
With camper 24 hwy/ 22 around town
17.75mpg freeway at 65+ mph in a 6 cyl auto frontier hauling an FWC Eagle. 4x4, oversize (heavy!) tires.
It seems about 3mpg lower than the unloaded truck for city or highway.
Of course we were southbound, that's all downhill, right?
Just got back from Colorado. We averaged 18.8 mpg. Between Espanola and Santa Fe we did a lot of mountain driving several miles in low low 4-wheel drive and went over several passes (Spring Creek Pass, Slumgullion Pass, Monarch Pass, Poncha Pass, Wolf Creek Pass). On the highway we keep it between 55 and 60 mph
  • Colorado Trip 2016 - Expenses.pdf
Dodge 3500 diesel (2013) with long bed, AT tires and a 2000 pound Alaskan camper. I get 12.9 doing 65-75. If I'm towing my horse trailer it drops to 11.
2015 Ram 2500 6.4 Hemi Longbox+ Grandby
Earlier this spring 12 day trip from Boise-Alabama Hills-Death Valley- J Tree-Disneyland-Hwy 1 up to SF- then Back to Boise through Reno and Winnamucca. Computer said 14.5 but I would guess hand calc would be 13-13.5 mpg
2017 Ram 3500 Crew Cab Short Bed 4x4 Diesel.
Best MPG: unloaded truck with no AC running... Got 21 at 70 mph.
With Lance 825 and 10,800 lbs gross weight. Full AC at 75 mph in mountains... 13.5. Usually 15-16 in the flats.
2016 ford full size transit 3.7 v/6 148" wb,Ls diff. mid roof, full camper conversion.
we now have almost 15,000 miles, back roads, secondary roads, few freeways.
over all avg. 18.5 more than i thought we would get.
really do not mis 4x4 any more, guess i'm getting old! (still have geo tracker 4x4 that we tow now and then)
Les,lqhikers
Over 12,000 mile trip: 20 mpg....... 23 highway at 70 and rock crawling dirt roads at 18 mpg. It is a 2.8 turbo diesel Colorado with Eagle.
2002 GMC 2500HD with Alison 5 speed transmission and 8.1L Big block gasser; Hawk camper. 10K miles logged.
Best was 12.87 mpg. Average is 11.11 mpg. at 70 mph I get 12. Got 10.87 on the Burr Trail. I normally do not set the cruise higher than 80 mph, even if that is the speed limit. Speedo check with GPS and is accurate.
2016 Tacoma V6 4 door with fleet flatbed - lifetime average 16.3 mpg over ~9,000 miles. Generally 15-16mpg on the highway at 70mph. Down to 12-13 mpg with a head wind, heading up to the divide or with speeds over 80mph. ~17mpg on secondary roads at 50 - 55mph, which is what we prefer.
dharte said:
2005 F250 Power Stroke-On my first big trip in March, (2,000 miles through Death Valley, Nevada and Utah) I averaged about 13.5mpg. On some of the 70-80MPH highways I had really strong headwinds and mileage went as low as 11mpg on some tanks . Before I got my Hawk, I had a regular camper shell and I would average about 15mpg. I wish there was a way to reduce air drag....
Update: I replaced my wide 17" mud terrain tires with a set of 18" take-off wheels and tires (Goodyear Wrangler) from a 2017 f250 and on my July trip through Idaho and Wyoming I averaged almost 15mpg. In addition to noticeably better mpg, I have a smoother and quieter ride and the truck still did great off-road.
dharte, is the tire diameter the same on the new tires as it was on the old tires?
cwd
Slightly taller with the new tires. My GPS mph display is spot on with my speedometer.
2016 2500 4x4 6.0 Crew 8' Grandby Shell. 13.5 @ 75 mph interstate empty. 12 @ 70 mph loaded. Hope to improve when it breaks in.
