Thanks, Frank. I think I'm going to learn more about circuits and electricity before I decide what to do
Meanwhile, I'll just recharge if needed through a direct connection to the charging system and pull a fuse when the engine isn't running so the truck battery doesn't drain.
That was my fall back solution to the problem,it works.Have you talked to Marty at All Terrain Campers? He could answer your questions the best. Good luck and be safe.
