Sure Power 1314 Recall - FYI
I will add my 2 cents we have been having problems charging the eagle camper for about a year. When I broke the front anchor bolts on the eagle down in the baja I took it into FWC to get them fixed. I also asked Stan about this issues his suggestion was to bypass the separator. Having no electrical ability at all I have been this year taking the battery out of the camper and charging it as I cannot get any charge to the battery whatsoever anymore not even plugging in the camper. Thank you for bringing this to our attention really appreciate knowing this is the problem to my camper as I have the model 1314 installed. It just pisses me off because I bought a brand new battery last year.....Oh Well. Will see if I can get a refund up here in Canada. If not I know what the problem is now.
Cheers Tony
Hoping for NFL Football
Has anyone heard anything from FWC on this issue? We have a 2010 Hawk and are concerned about it as we are about to head out for a month long trip. Does anyone know where I would look for this surepower unit in the camper?
Michael
Michael,the separator should be in the camper where the battery is.As I have posted Jim Smith (Smith Auto Electric) has said that the 1314-200 is made for alternators of 100 amps or more.The 1314 may not be right for that amperage.That is what I got from the conversation with Jim.Stan has not said anything about this that I am aware of.There are several web sites to order the replacement from.I didn't ask what Model Sure Power was going to replace the 1314 with.I didn't wait around for their replacement and will take the refund and put it towards the new one.
Hope this helps.
I just received the new separator and installed it zip-snap.The blue terminal is the main battery. It seemed to be a bit confusing ,but a little trial and error works. The 1314-200 is on the right. Quit a bit bigger than the 1314. Just by looks and heft the new one would seem to be heavier duty.If there are any changes in this install I'll post.Sending the old one back for a refund.If this is the route you take call the Sure Power co.and talk to Judy and she will get you set up with a UPS return label.
Just pull the fuse when using the camper battery, reinsert when you want to charge. Basically the same thing the separator does, opening the circuit.
Dsrtrat
I'm going to just run without the separator for the rest of the summer and straight wire the truck charge line to the camper battery. I'm really not at risk of draining my truck batteries in the summer now that it is finally warm enough to not need the heater.
It will charge all the time - which will be better than not charging.
Frank,
Please explain. My understanding was the 1400-200 was for a 200 amp alternator. I also was led to believe that
Sure Power suggested it not be used on vehicles that don't have 200 amp alternators. Further I thought most vehicles have something less than a 200 amp alternator. When you called Sure Power did they tell you something different?
Frank,
Jay when I talked with the Sure Power people they didn't give a lot of info. It seemed they didn't want to commit themselves and would NOT exchange the 1314 for another separator except wait for the unnamed model sometime in Sept. or get a refund.Now when I talked to Jim Smith (Smith Auto Electric) his recommendation was the 1314-200,which is made for 100 amp alternators .If I read the info right the 1315-200 is made for the bigger 200 amp alternators.Jim also said he has recommended to the Sure Power people that they need to upgrade or not make the 1314. I am not just sure if there is a real problem with the recalled models BUT I can't take the chance. IOM it's strange that ATC/FWC haven't gotten in on this issue.Do they still use them or have they gone to something else? It would be nice for them to add their comments.The main issue is than if you have one of the recalled #s to do whatever you need to do to be on the safe side. Still hope all this helps.This is what works for me.
Thanks for that info Frank. ATC is on it and they're going back to the solenoid method until Sure Power gets the new units in. ATC and I have contacted all of our owners and sent them the recall information. I too will be waiting for one of the new units.
Thanks Jay. I knew Marty would come through.Thats why I bought my Bobcat from them. What do you mean by the solenoid method?
Just a heavy duty solenoid with a heat sensing device. Many of us used this method when we wired our trucks in the past before the separator was OEM. I still have one installed under the hood of the Dodge. It's no longer connected but it could be put back into service pretty easily.
I just spoke with Surepower tech support.
I have a Nissan Frontier with a 110 amp alternator. Their recommendation is to go with the 1314-200 as a better match. The 1314 would be adequate but it would be on the edge, so bigger is better. However, it will require heavier wiring, the posts are bigger, and the ground is bigger. I need to look at the tech specs to find what is required.
I got my 1314 from ATC, so I need to check what my wiring and terminal sizes are.
It makes sense that Surepower is not saying that the 1314-200 is a replacement for the 1314, because in all situations it isn't, it is dependent on the alternator size.
Here is a suggestion for those who are by passing and waiting til Sept for the replacement. Why not wire in a manual throw switch between the starting batt. and camper batt.
My Phoenix camper came with a solenoid so i was wondering what are its short comings when compared to the Shure Power seperators that are working correctly?
Rob,my 09 Bobcat needed no changes to the wire connections.The1314-200 even though it is a bit larger there was room for it in the battery area.Yes I agree the people at Sure Power don't want to get into recommendations but I just felt some help from them was forthcoming,but I did get the info I needed so it's done, installed,shipped back for refund,FINISHED! The important part is that this was caught before any possible problem.
I have been crawling around trying to find my battery separator. So far no luck.
The FWC manual helpfully suggests that the battery separator is "usually located in the cabinets".
It might be fun (and possibly useful) for those of you who have found separators to share in what unlikely spot you found yours.
I think the recommendation of using the 1314-200 is based on using the separator to charge at full alternaor output - which in the case of our campers is all but impossible. Our campers are wired with small enough wiring that unless you rewire the charge curcuit all the way from the truck to the camper battery to MUCH larger cable you can not push enough amps through it to even get close to the 1314-100's capacity.
If you are using the SurePower under the hood of your truck to charge a second battery that is conected with big battery cables and you have a 100+ amp alternator the 1314-200 is probably what you want. But if you only have a 6 or 8 gauge wire running back to your camper, charging off a 30 to 40 amp fuse or breaker - you just do not need the capacity of the 1314-200. You can't push more than 40 amps past your fuse to the separator anyway....
Look where the battery is located.
You didn't happen to mention what camper you have.
I have a FWC Hawk 2008 model. It was located in the cabinets (lower right hand side below the thermostadt)....with one screw hidden under the lid over the water tank. You have to remove the lid to the water tank to see it. I also had to remove the small flip down door in order to slide that piece of wood out. Maybe some pics would help.
Thank you Leadsled. Pictures always better than words. My guess is mine is in roughly the same place but getting there may be a bit harder than it was for you. I have an 2009 Eagle with some relatively new (for then) options they were just trying out. I will have to dig out the screw driver.
In my 2008 Eagle, the battery and separator were in the storage area under the couch on the passenger side. When the dinette conversion was done, both were moved to the front storage area. Hope you find your elusive separator without too much trouble.
Thanks Mr.UglyScout. I understand the info you stated and realize the 1314-200 is more than we need.BUT I needed something to use as a replacement and not being able to wait until Sept. nor wanting to just wire both batteries together I went with Jim's recommendation. It seems to work with no problems,charges the house battery with the reefer in 12v mode.
Four Wheel is working closely with Cooper Bussman on the best way to handle the recall of Cooper Bussmann's products. We are discussing with Cooper Bussman the specific directions and procedures to follow. We have noticed on message boards comments about how a person could on his/her own rectify the matter. Please do not take any action on your own. Please wait until we can provide accurate information for each of you on what to do. Any unauthorized attempt to service, repair, or dismantle the separator could void any and all warranties. Do not attempt to (i) open any cabinet panels, (ii) rewire any aspect of the electrical system, (iii) remove the separator, (iv) install a solenoid, or (v) take any action that modifies the equipment from its original condition. Doing any of the foregoing could damage or destroy your vehicle computer and place you and others at risk for injury. Thank you for your patience, and we will contact you very soon. Tom Hanagan, President, Four Wheel campers, Inc.
