Hello again... just out of hibernation of New England and about to head to Kentucky with the 2011 Eagle on the 2001 Tacoma. I had installed the roof lifts last fall and then had to wait. A week ago I was able to load the camper and see how things held out with the winter cold...whoa a cold one here. I tried the roof lift and it was not nice. I used the factory install method ...made a 40" template arm so I positioned the arms correctly ( recall the front roof clamps had to be moved out to get the right lift position). The front worked great but the back, even though I used the FWC 40" template for the 40" required lift supports, the 'stretch was too far out . The directions received from FWC was to put the lift bracket ball up against the roof clamp.I did that and speaking from a 2011 Eagle stand point that is not right. I decided the geometry of the lift was wrong... I could feel it did not have the lift needed at the right time of the radius swing of the lifter. I decided to be yankee conservative and move both lifters in on the roof 1.5" so that I could use one of the same drill holes. Sure enough ...wow... a huge improvement. The roof lifts with only a push instead of needing the crank. And most importantly at the top of the arch... it gently allows the panels to pop into place... no hard snap. I am very happy. I did plug the extra hole with a screw and silicone. So we are off to KY and then Virginia George Washington National Forest and on up to PA and then home. I just wanted to let anyone who decides to add lift supports to their Eagle (needing the 40" 30 lb supports) if they need help just ask and I can give what info I gained in the process.
